According to Instructions you should fill your gas tank up all the way since that needle is the most sensitive to re adjust.. but all you have to do is turn the ignition mark all your gauges and your set. Another way my friend told me is to slip them on with out even touching needles. Slightly bend them and slip on.....where are you located? and is it easy to re calibrate the needles once removed?
