Can anyone please advise the best break in procedure for my engine, I’ll paste my build
In here!
BC camshafts require first start up at 2.5k revs for 20minutes to bed the camshafts in.
Manley pistons suggest highway driving, or 2000-3000miles on the street or one might racing on the track to seat the rings adequately.
So my question is what is the best option for my break in?
Obviously I will have a safe base map on Syvecs ecu, and on the first key turn I will hit 2.5k revs for 20minutes but it’s what to do after this. I do have access to a dyno where the car is sitting.
Repainted ported Head -
Toyota gaskets and seals replacement.
Professional skim.
New manifold nut & bolt kit.
New ARP 8740 head stud kit.
Ported exhaust side.
3 angle cut valves.
Shim gapped.
New Bc Stage 2 - 264 camshafts.
New Bc spring & titanium retainer kit.
New iridium Grade 8 spark plugs.
New Toyota oem coil pack.
New Toyota coil clips.
New ventilation hoses.
Repainted forged Block -
Toyota gasket and seals replacement.
Professional Honing and skim.
Balanced micro Polished crankshaft.
New Balanced Manley H-tuff 625+ conrods.
New Balanced Manley turbo tuff extreme duty pistons + extreme wrist pins.
86.5mm 9.0:1.
New King race pMax main and conrod kit with thrusts.
Arp 8740 main stud kit.
Tomei 194009 Type-R baffled sump kit.
Srd oil level blanking plate.
Magnetic sump plug.
In here!
Professional skim.
3 angle cut valves.
Shim gapped.
86.5mm 9.0:1.
Magnetic sump plug.
