1 - 3 of 3 Posts
Bad Texan Boy
I was wondering if you guys ever had an experience with Brembo brake discs (stock style)? It cost about $80 cheaper than stock and I wanna know if it is good since Brembo is hot and popular. Also, I wanna know if it can use stock pads and calipers.
Right now, two of my brake discs are crossed and other two are stock, it was like that when I bought a Supra.. I just want to have all new brake discs at same time.
http://www.nopionline.com/nopistore...vmakeid=420&vL1id=0&&vtitle=TOYOTA Supra 1996
Super Moderator
If you're not going to get the Brembo cast iron discs with the chamfered, cross-drilled holes machined in (the kind that come with the Gran Turismo and up kits) or slotted only, you're better off with the stock discs. I believe the OEM discs to be superior to the Brembo OEM replacement discs, and there's a reason why the Brembo OEM replacements are less expensive than the Toyotas. For your application, and almost everyone else's, stock is best.
Ken.
RSP fetish #23 GTR driver
I was always curious about Brembo rotors too.
It's a pity that Brembo Gran Turismo kit (brakes plus rotors) will not work with stock polished wheels.
Btw, stock cross-drilled brake system on my M3 competition is far superior to Supra stock brakes. I would love to have this kind of brake system on my hardtop.
1 - 3 of 3 Posts
