1 - 20 of 22 Posts
Master Shit Fixer
Any tire store can do it too.
7M Fanatic
Probably why you have a broken stud in the first place.
Most tire monkeys use an air impact wrench to run wheel nuts on, then check them for being tight enough with a torque wrench, even though they are way too tight, and over torqued already.
And if one was stressed to the breaking point, the others most likely are already close to that point..
Shame to see a vintage performance car run into the ground by bad maintenance....
Master Shit Fixer
^ Yep. Don't let tire shops use an impact wrench...always ask for lugnuts to be hand installed/hand tightened. Hell, I don't even bring my Supra to the tire store. I just remove the wheels, throw them in my truck, and deliver them to the tire store for tire mounting and balancing.
Discussion Starter #9
I will remember that, because I have custom lug nuts
100% this.
Hell I am considering buying a tire machine and balancer just because I don't trust any of them with a $3k set of wheels.
in general tire service is done by entry level techs. guys that graduated up from oil changes, you know after you strip x drain plugs they put you on some manual labor tire work
so much to.go wrong..... incorrect weights trashing your rims lip. cutting out your expensive chrome valve stems and replacing with way to long/short stems.
ruining your expensive psi sensor on your gm rims
directional wheels and tires
aligning the dam circle mark on the tire with the valve stem hole
my local shop will let me hover over them and pay cash when they are slow.
a good (safe) bead lock machine is expensive though. I have a basic coats 1010 and you can get most stuff <17" but you have to be very careful w older style machines and use nylon shims etc to protect the rim. plus when you get a machine then everyone all of a sudden wants to stop over with a tire.
Oh,I have never broken a wheel stud. LIAR!
It's usually the fault of the last 400 pound gorilla that rattled on your wheel nuts.
Got expensive wheels and custom lug nuts? Buy or borrow the correct tools and DIY.
There is the fast way and the right way to replace a wheel stud.You must choose.Put down that hammer!
I do the exact same thing. Hell, if I could afford it, I'd have an alignment rack at home, have yet to find a local place that has any understanding of what "torque spec" means...
Discussion Starter #15
I don't want to do it myself, I would rather pay a shop, I guess I won't go to discount tire, thanks.
How did you break the stud?
If you have the replacement, take it and the hub to a machine shop and have them press it in.
It's ok to use an impact to put studs on, but turn the pressure down, doesn't need to be full tilt. Just use it to get the bolts on and secure, and then tighten them snug plus a quarter turn. Drive a little bit, make sure they're all tight, all good.
Master Shit Fixer
Uh...no. Bruder is correct...tighten them evenly, and torque them with a torque wrench. Retorque after a few drives. "snug plus a quarter turn" is not the proper way to do anything, especially lug nuts.
1 - 20 of 22 Posts
