Well... After I spit a shim yester year, I ended up damaging the head a little as the shim dug in... Now the bucket won't come out easily and I'm not sure how to force it out. I thought I had bent a valve but it looks like I didn't. #6 is a little melted which explains the lower compression and the oil appetite.
Anyhow I usually use a magnet to pull out the bucket but I can’t seem to get pliers on the bucket to pull it out nor can I get a magnet strong enough to pull it out since it is very tightly packed in there…
I’m able to get it back to the top by pushing the valve from the bottom of the head but how the hell can I pull out the bucket other then the magnet and pliers? Any ideas? Was thinking I may have to drill though it and stick something like an Allen key in there.
I even tried compressing the srping by putting 3 shims in there having the cam tigten down to compress the spring and lodging something in the valve to hold it open.. Then when I pull off the cam i pulled out the what was holding the valve hoping that the spring of the spring would shoot the bucket out... Well got half way but no dice after that....
