Soooo, I was coming back from Arkansas yesterday, I noticed on some parts of the drive the car would buck horribly. I actually noticed it more when I was on the gas a little cruising, then let off a small amount (read: the AFC was showing 12% throttle, back it off to 6-8%). It did it still when I would just let off the gas completely, though not as bad and not as often. Mainly when I would be cruising and just back it off a little. This just started yesterday, and it happens at all ranges of RPM. It did it when I was going 70 at 3200 RPM, at 20 miles per hour at around 2000RPM, so I know it's not just doing it when the RPM gets too low.
What could be the cause of this? Also, when I let off the gas now, even before I boost or anything, the RPM will hang at around 1800-2000 then drop to 1000 rapidly, hang for a split second and then try to die. Could a leak in the IC piping couplers cause this?
Setup:
DaveH PT52 kit
Tial 38mm atmospheric dump
Greddy Type-RS - not re-routed
stock fuel
3" exhaust through midpipe, stock backhalf
I tried to pull over and look at the car, but by the time it had started doing it, it was dark out and I couldn't see crap...I have yet to go out there and look at it today.
Thanks,
Bryan M.
Setup:
DaveH PT52 kit
stock fuel
Thanks,
Bryan M.
