1 - 20 of 28 Posts
What's up! I've been taking pics of my project so far and want to share them with you. I got my Supra from my grandpa when I was 16 (I'm now 28) and it had issues all throughout high school until it finally quit in 09. I was able to store it all these years and now I have a garage of my own to work on it, and I'm really excited to get it started again. I owned an SC300 after the Supra, which was totaled by a bad driver some years back. I took the 2JZGE out of the Lexus and have been storing that as well. Enjoy!
Here is a pic from 2009. 18 year old me wanted stripes so bad that I repainted the entire car just so I could add them. I thought they turned out pretty nice at the time lol! 5 horsepower each.
244067
Here is a pic of the 2JZ before attempting to restore it. Very dirty!
244069
Looks like we've got a valve cover leak going on. This took a while to clean up.
244070
Picture of the front before I cleaned it up.
Breaks needed to be replaced, so I went ahead and got that done. I also painted the calipers a blue color. Will post pics.
244073
You can see where the valve covers were resting and the residue left behind.
244074
I carefully used a dremel with a small wire brush fitting and they clean up nicely. I wanted the surface smooth so they seal properly.
244075
Goodbye stupid Y intake
244076
Nice looking eBay exhaust manifold. This will hold me over until I go turbo.
244077
Discussion Starter #2
So the original 7M motor mounts literally split in half lol. Wow.
244078
New ROUND mounts came in. Since mine is a 1991 I cannot use SQUARE mounts like previous MK3 versions. Just trying to throw in some info as I go along.
244079
This is the 7M pressure plate which needs to be used with a 1JZ flywheel and 1JZ bellhousing
244081
Repainted it black with high heat paint because aesthetics. Turned out nice.
244082
Exhaust installed. It was super easy and came with new gaskets.
244083
Old exhaust - who wants this thing?
244084
New Chromoly 1JZ flywheel
244085
I thought I'd be able to use the bellhousing from the auto trans, but I was sadly mistaken. Totally different. Here it is below.
244086
Here is the auto trans A340E if anyone is interested. I have no use for it.
244087
This is the 1JZ bellhousing which mounts perfectly to the R154 transmission
244088
Discussion Starter #3 (Edited)
Time to pull the 7M out - trying to get rid of this as well
244089
I took off the 2JZ timing cover and decided to paint it a pearl white. Hard to see with lighting but it turned out nice. I used a white gloss base coat before the pearl paint. Will post better pics later on.
Here is a before and after. I installed a FFIM that came with a new fuel rail, etc/ I painted the valve covers blue, but then decided black would look better. Updated pics coming soon. I got the pulley set from drift motion. When taking off the alternator pulley, you want to use an impact, it's so easy.
244094
Not looking to buy new rims yet, but I wanted a color change.
244096
I just used plastidip, so when I get sick of the color I can just tear it right off.
244097
Going to get rid of distributor and use the CPS/Coilpacks. I ordered a new cover for it from drift motion. I'm hoping it's still in working condition after all this time. Thoughts?
244100
Here is the bay after I pulled 7M. Super dirty, and to be honest I'm not familiar with all of the lines on the fire wall besides the ABS ones. Going to be a lot of work figuring all of that out.
244102
Helpful pictures i found floating around on the forums, these aren't mine.
244103
244104
244105
MORE TO COME! I want this thread to be a complete start to finish. I'll start taking more pics of the process for each thing as well.
Hi, I'm new to this, however if u purchased that header from said place, it might not fit the Ma70 body, the angle on down pipe is off. Chech be for scratch it. Tried it with mine. Will u be using same intake manifold setup? Please let me know or what mod is needed. Thanks. Good luck
I'll be following your 2JZGE swap and especially interested how you'll go about with wiring. Are you going to be sticking with factory ECU? Or a standalone?
Those black stripes made it look like a camaro when I first looked at it...…….lol
Good luck with the transformation.
Discussion Starter #8
Appreciate it! For now I’ll be sticking with the factory ECU and upgrading to standalone once I have the funds. I’ll be taking tons of pictures for wiring and the connectors so that people have something to look at for reference.
Dude I know ? I’m torn on what to do now. I’ve had those stripes for so long it would feel weird not having them. We shall see.
Im watching this to see how the na 2jz runs on the 7mgte electronics (I have a hunch it will run good as the off boost/low load maps on the gte have lots of advance)
a few questions
are you running the 7m 440 cc injectors / stock 7mgte air flow meter housing
7mgte has two knock sensors. are these compatible with outputs from the sensors on the 2jz ?
if you throw a knock sensor code it will retard timing a lot. you can run a single knock sensor and split it into to at the ecu (a small jumper soldered inside the 7mgte ecu bridging both knock inputs). I run this on mine and it does not throw a code (I run a 7mge block w a single sensor)
Discussion Starter #10
Thanks for the follow! I’ll try not to disappoint lol. I get a lot of good info from your posts so hopefully I can provide the same.
So to answer your questions, there’s a ton of misinformation regarding injectors and sizing across all of the Supra forums. The most accurate info I could find is in this picture.
244224
For everyone’s knowledge, they are not all interchangeable across engines. Top feed and side feed are totally different. Low impedence and high impedence are also different. You can use low impedence injectors in place of high impedence, but you need a resistor pack IIRC an 8 OHM resistor pack.
I’m going to run my 2JZGE 315-330CC stock high impedence injectors OR the stock 550CC 13b Turbo II RX7 (plug and play) and are also high imp.
The knock sensors from the 7M will fit right into the 2J but the 2J knock sensors will not work because the plugs are different.
I’ll be using the Lexus AFM but I have the 7M AFM on stand by in case.
Discussion Starter #11
Small Update:
Front bumper is off which was a pain in the ass x 2. Lots of rusted bolts and broken clips.
245298
Nasty dent from when I was 16 and barely tapped the car in front of me. They had a trailer hitch and it bent the metal. Guess I'll need to take this off and the to remove dent. I also bought a sand blaster which will help with the rust.
245300
I'm running a very similar setup. I completed the swap in '08 and have been running the 2JZGE on 7MGTE electronics and ECU. I've since added an ECUMaster DET3 to remove the AFM. I'd love to hear how the FFIM fits in the chassis, and which one you purchased. That's the next item on my build list.
Great work so far, man. Looking forward to seeing the progress!
-Nick
Discussion Starter #13
-Nick
That's awesome, good to know someone who has a similar setup to me. Updates coming soon!! Will let you know how it all fits.
Newbie question here: If just running a stock 2JZGE, wouldn't using the accompanying 2JZ harness and ECU be an easier option compared to re-using the 7MGTE ECU?
the cps (crank position sensor) from the 7m physically fits in the 2jzge (non turbo, non vvti) cylinder head.
the only electronics you are then dealing with are the sensors-- coolant temp / tps/ fuel injectors / etc
but its straightforward 1:1 stuff and simple compared to removing the 7m engine wire harness and swapping in a new 2jz harness and then interfacing that new jz harness/ecu with the existing mk3 chassis wiring (if that makes sense haha)
this is only in the scenario where you are starting with a car that has the 7mgte of course.
doing the map conversion: physically taking the air flow meter out and replacing it with electronics that recreate that afm signal is 100% the way to go imho. more precise fuel control than a safc, but has simple piggy back setup.
then, of course add some turbo. it pains me to hear guys running na jz swaps. not like bmw engine pain...but still add some compressed intake air man ;)
Y
Yeah, you turbo guys are killing me, LOL!
I do have a 7MGTE that I'm real happy with.
But it's my 87 7MGE with almost 200K miles that I've been looking at for an upgrade. There's quite a few na jz's available near me that it's very tempting to do those instead of sourcing an imported 2JZGTE's.
Another big consideration for me is that it might be easier to pass California SMOG test with the na.
Thank you for the info.
Discussion Starter #17
Alright boys. Here's an update. This week, we're working on cleaning the head because it's nasty.
249256
The tiny wheel north-west of the crank is the tensioner for the timing belt. I compressed it with a simple c-clamp after I got everything set to TDC (top dead center). Piston 1 and 6 will be raised to the top when you remove the head. There are many write-ups on how to get it to TDC. I put the crank bolt back in, and was able to just use a ratchet to turn the crankshaft.
249258
Next was taking out the camshafts. As you take out each guide with the bolts, put them in baggies labeled exhaust side or intake side.
249259
This is straight from the bible. Make sure to loosen the bolts in this order. Go through and loosen each bolt as shown, then go back through and take them out as shown. Some of the guides may STICK because of residue. If you're having trouble getting them off, dont use anything metal as you might scratch the head. I ended up using a few light taps with a rubber mallet.
249260
249261
Camshafts are out! I bought a plastic bin specifically to store them temporarily with a bit of oil so they don't rust.
Discussion Starter #18
249262
Next were the head bolts. Do them in this order, loosen first time, remove second time.
249263
Picked up a small set of these for like 10 bucks at Advanced Auto. The is what you need for the head bolts. Also, dont try to crank them using a ratchet lol, you'll break your hand. I used a break bar and even with that it was tough, but the all came out smoothly after the initial "creak".
249264
HEAD IS OFF! How do my piston walls look? Definitely needs some cleaning before the new gasket goes on. Will post pics once that is complete.
249265
249266
249267
It's worth it to note that I won't be turbo'ing yet. I want to save up for nice parts and do it right the first time around. I ordered new stock head bolts, because the stock ones tend to stretch over time due to the intense heat and pressure. That is why a lot of people do ARP head bolts, because they don't warp. For practicality I;m fine with stock for now. Once I go turbo I'll be picking up ARP studs and bolts.
Also note: On the GE, the head gasket is way thinner to create higher compression to make up for the lack of boost.
Discussion Starter #19
Hey guys. What's the bets method for blocking off coolant/oil ports on the block? Going to start cleaning the mating surface this week, but don't want all that gunk falling down in the ports.
Any more close up pictures of the piston tops?
You want to rotate the crank and as the piston is close to TDC, that is when you take a picture. 6 look ok (assuming that what was posted).
1 - 20 of 28 Posts
