1 - 3 of 3 Posts
Hello,
I was thinking of buying a used SP67 budget kit...
Here's the questions, if you can please answer:
Can you use a stock IC and MAF for this turbo?
How much can I boost with stock IC and MAF?
How much HP would I approx have?
How much would it cost if you guys installed it, with no removal charge of the stock twins?
Is it work getting a MAP ECU?
How much to tune the MAP ECU, if I have it installed already?
How much does the SP63 cost?
Thanks - so much...
MY Car's Info (you might need this)
1993 Supra TT Auto
-Greddy BCC
-DP & Exhaust
-HKS SSBOV
-Air Intake
-Stock MAF and IC
-Stock feul and injectors
DO WORK!!
Let me know if you have any more questions
Hello,
Yes
With the 67 I would say no more that 17 to 18
400 rwhp Give or take
It all depends on what header you have... 8 - 12 hours
It requires me making a phone call... But I would stay away from the map ECU. I dont think there is anyone in the US that sells them anymore. Look for an HKS VPC or the MAFT PRO
Tuning is $200 an hour You would be looking at about 2 hours if installed correctly
$1021 for the Journal Bearing
$1900 for the ball bearing
$150 for the oil line kit
$150 if you need the Waterlines for the BB kit
Thanks - so much...
You will need a Different Down pipe and Mid pipe if you get a single turbo
1993 Supra TT Auto
-Greddy BCC
-DP & Exhaust
-HKS SSBOV
-Air Intake
-Stock MAF and IC
1 - 3 of 3 Posts
