1 - 7 of 7 Posts
I am buying a new oil cooler. I am going with the relocation kit and the na filter stud. Will this kit work?
Brand: Summit
Product Line: Summit Combination Fluid Coolers
Part Type: Fluid Coolers
Overall Height (in): 10.000 in.
Overall Width (in): 17.500 in.
Overall Thickness (in): 0.750 in.
Cooler Construction: Tube and fin
Cooler Material: Aluminum
Inlet Size: 3/8 in.
Inlet Attachment: Hose barb
Outlet Size: 3/8 in.
Outlet Attachment: Hose barb
Number of Cooling Rows: 4 and 2
Core Height (in): 10.000 in.
Core Width (in): 14.750 in.
Core Thickness (in): 0.750 in.
Cooler Finish: Natural
Quantity: Sold as a kit.
Fluid Cooler, Engine/Transmission, Tube and Fin, Aluminum, Natural, 10 in. x 17 1/2 in. x 3/4 in., Each
I am also buying the thermostat and was going to use this cooler for engine and power steering. Just want to make sure it will be efficient enough. Dont want to get rod knock.
going broke fast
i'm going with an-10 fitting's on mine.3/8 size line will be good for the power steering or an auto tran's
Grumpy Old Man
-10 is good :D
(means any 90's will still flow well as 1 x 90 bend = 10 feet of straight restriction wise)
So would 1/2 inch in and outs be ok? They have a B&M kit 8 in. x 11 in. x 1 1/ 2 in (part number BMM-70270). Tthen I get the relocation kit they have for 35 bucks plus the thermo and I should be good to go?
1 - 7 of 7 Posts
