1 - 8 of 8 Posts
I just got my iforged wheels
front 19x9.5 with +42 offset
rear 19x10.5 with +48 offset
i was looking at tires forthese wheels and found out that the largest i can go without rolling fenders is
275/30/19
245/35/19?
I was going to byt eh bf goodrich kdaw 2, but the place is backordered on the 275's.
I cam across the Kumho SPT tires, they are about 200 bucks cheaper, and seem to be decent, anyone have any experiences with these tires?????????
aKa Blk96SupraTT
I got some Volk GT-AVs. 19x8.5F and 19x9.5R and i'm running the BFG KDW. 245/35/19 F and 285/30/19 R. i have no rubbing issues in the rear but the fronts were rubbing.
Zoom-Zoom
From everything I've read, the Michelin Pilot Sport PS2 or the Goodyear Eagle F1 GS-D3 are the two best non winter, non drag radial tires that you can buy. Check out tirerack.com and 1010tires.com. 1010tires also has a tire size calculator that shows which sizes are similar in diameter to the stock tire, how similar they are, and which tires come in those sizes.
http://1010tires.com/TireSizeCalculator.asp
Bridgestone S03's are nice and they run a little narrow on their sizes so rubbing shouldn't be an issue. With your offset, you could even run a 285 and get away with no rubbing with such a + offset.
ok i ordered my tires from tirerack. They told me the 245/35/19 tires for the fronts would be too big. I told them its a 19x9.5 and they said it should be fine etc.
isnt that size the normal for a 19x9.5
I ran 245/35 on my 19x8.5" and it looked flush. On a 9.5" wide wheel, that will looked stretched.
do u think it will look bad, or just a little stretched, tirerack already shipped the order, so imma put them on. Jus tryin to give myself a peace of mind that its not gonna look ugly
Let's go Phils
245 and 275 is gonna stretch a bit. I have 19x9.5 fronts and 19x 11 rears. 255/35/19 front and 315/25/19 rears. No cutting, rolling, etc.
1 - 8 of 8 Posts
