Is the difference that big between C12 and C16 race gas? Anyone know how big the cost difference is between the two? I am leaning to towards C12 because I am looking to only get about 650whp out of my Supra.
IF your just shooting for 650whp then the C12 should work for you because you'll only need to run 20-22psi with a 71 to make that power.I have a T72 with a AEM stand alone and dual fuel pumps with 950cc injectors. I do not have any head or CAM work done.
Q16 is oxygenated fuel and will require more fuel than C16. Since it is oxygenated you'll make slightly more power. I've also heard that Q16 is more forgiving when it comes to tuning.not to steal your thread but whats the difference in c16 and q16?
900+HP Safe?how safe it is to run high boost on e85?
~600 on pump gas. you can prolly get 650 on standard sunoco pump 100 octane if you guys have it down there. talk to your tuner, on my setup, I would feed comfortable ~650 with just 3-4 gallons of 100 in on top of 93 Octane.Is the difference that big between C12 and C16 race gas? Anyone know how big the cost difference is between the two? I am leaning to towards C12 because I am looking to only get about 650whp out of my Supra.
GL.
You'll probably have to upgrade to a 71 and run E85 or a less expensive race gas in order to do that.I run c16, my wallet hurts.
I need to start thinking about how to get 650whp on pump, meth is coming to mind, but id rather not go that route.
That's what im thinking Steve. Cant that make 700whp or so on E85?You'll probably have to upgrade to a 71 and run E85 or a less expensive race gas in order to do that.
Steve
So jelous, can you share your setup? Spool? Full boost at?I make 714rwhp on 94 pump and 100% meth on my T88. Its possible.
R.K.
