1 - 20 of 205 Posts
re-born
Allright guys this question comes up every few mins
So lets start a list of all the known shops in CA
Just reply with the Name of the shop, address, if it is norcal or socal, and positives/negatives about it
I will add them all to this first post
Nor Cal
ATP
[email protected]
http://www.atpturbo.com/
Phone: 510.445.1682
44777-G S. Grimmer Blvd.
Fremont, CA 94538
AWD DynoJet
Mustang Ranch
http://www.mustangranch.biz/
(408) 247-9005
1375 El Camino Real - Santa Clara, Ca 95050
Dynojet
Vishnu Performance
[email protected].
http://www.vishnutuning.com/dynolab.htm
(925) 924-9800
3687 Old Santa Rita Road #21
Pleasanton, CA 94588
AWD Australian Dyno
re-born
it just isnt SAE HP
it really doesnt matter what your HP is if your just tuning, if your making max power on that particular dyno with proper A/Fs and what not then it is good
this isnt the where to get the biggest numbers thread"
but where to get your car tuned thread
Matt Hunt from UPRD was the only guy who could fix the boost leak in my 97 BPU. I went down there on a Saturday morning and he fixed it while I waited.....broken piece of IC piping, he also sold me some used BPU parts and installed them at a great price.
dynmicracer, i think the list of links is misleading... for example, i did take my car to DynoSpot 2 yrs ago in hopes they could fix a problem (they were close by work..)
they really have no idea about supras... maybe fine for dynos only...
Ex APU Supra Guy
Yeah good point. I have been meaning to go in and rearrange them but just have not had a chance. I will.
Alex
TL211 said:
Vishnu is a good place for WRX only not for supras
if you dyno your supra at Vishu you will get really low numbers because his dyno is not a dynojet
True our dyno reads lower than a Dynojet. But you will get a good tune done to your Supra and then you can go to Dynospot or ATP for the horsepower chart to post as they both have the higher reading Dynojets.
Brett.
For Maintenance and any bolt-ons:
Mo's Garage
2005 N. Tustin Ave. #C
Santa Ana, CA 92705
714-834-0256
I've known them for over 10 years, and they are knowledgable, honest and their prices are fair. And most importantly, they will stand behind their work 100%. They have 6 lifts and are very well setup to handle any maintenance and repair.
From the people's Supras I know of, the major things they've done are:
Timing Belts 10+
Clutches ~15
Head off incl. valve stem and turbo seals 2
Head on valve stem seals 6
Stock turbo rebuild/replacement 6+
Entire longblock out of the car 5
Wheel Bearings 4+
etc.....
I just negotiated a special fixed special rate for Supra owners, though they've worked on probably 30 Supras including mine.
$75 and hour (vs. $85 normal rate)
15% off OEM Toyota Parts (if you don't get them from Curt of Jeff)
Clutch Labor $500
Wheel Bearings ~$275
FMIC Install $350+ depending on what kind.
Engine Swaps, Major Work, Maintenance, etc.:
Sarkis
DynoXtreme
8042 Cerritos Ave., Suite F
Stanton, CA 90680
714-231-4299
www.dynoxtreme.com
Wheel Repair:
Custom Wheel Service
3158 E La Palma Ave
Anaheim, CA 92646
714-632-6700
www.customwheelservice.com
By far the best wheel repair contacts around. They've had wheels fixed for friends of mine that other shops said couldn't be done. And I had them completely redo my wheels and they came out great.
Cryogenic (Cryo) Treating Rotors:
Applied Rotor Technology
4431 Corporate Center Dr. Ste 115
Los Alamitos, CA 90720
(714) 527-9400
http://www.appliedrotortechnology.com
Normal price is $70 per rotor, but I'm working on a discounted price for Supra owners.
Fabrication Work:
Brian Darnall
(714) 356-3855
Matt Hill
Performance Solutions
2730 Gondry
Signal Hill, CA 90806
562-490-0117
UPRD and R&D Dyno
Here's my experience with both. UPRD is slow and I suspect they don't install the parts they say do. I had gasket goop on my downpipe instead of the right flange gasket. They threw out my very EXPENSIVE Toyota hose clamps and use ty-wraps. How long do you think those will last under heat/time? Where's the photos they promised me? R&D Dyno is a hole! 3/4 of the time they loose the RPM signal during a pull. They don't know enough to put a fan on the IC, etc., etc.
Let's hear from others!
1 - 20 of 205 Posts
