201 - 204 of 204 Posts
Mr. 2JZUL8R
dont mean to butt in but was wondering if Alex from l-spec knew a thing or 2 about 1jz's? i just recently purchased a 1jz mk3 and dont have a set mechanic as i cant do maintenance on it because apartments and bitchy neighbors..
Sure he does. We dropped off Jill's 1j Mk3 earlier this year for a major maintenance overhaul! Performed:
Power steering pump rebuild
Replaced all brake pads/rotors/lines with Stop Tech components
Replaced wheel bearings
Resealed upper and low oil pans
Resealed transmission
Rear main seal
Timing belt
Crank seal
Cam Seals
Tensioners
Serpentine Belt
Flushed/Replaced every fluid in the vehicle
Replaced center carrier bearing for driveshaft
Sway bar end links
Repainted a few components next door at the body shop
and did a few other minor things
thats good to know :D,ill be taking it in hopefully this weekend as i google mapped it and its literally 1 main street down a couple streets haha,thanks nick
@mysupratoy94 and @pakoemon, i know it's been a long time but did you guys ever end up going to L-Spec for the work that needed to be done? Just curious. thanks.
Looking for a shop in Northern California that can handle a os giken twin plate clutch install 1jz/r154 on 240sx. TIA
Chris
