1 - 16 of 16 Posts
Nominally, new would be the best choice, but for now purchasing a rebuilt or buying a rebuild kit are my options. Does anyone have any pros or cons for these options?
I'm taking care of some other things right now (so it'll be a few weeks before I do mine), but I ordered the rebuild kits from Autozone for less than $20 total (all 4). They do not include new bleeder screws like the Toyota rebuild kit. However, I don't need those bleeders, 'cause I got replacement speed-bleeders off Ebay that I will install when I rebuild 'em.
Now, before everyone else jumps in... the TRSM shows the rebuild/replacement process and it does not seem too hard to do. If you are unsure about it, might as well get the rebuilt ones and have less to worry about. I believe that they run about $75 for each rebuilt caliper (not from Toyota tho).
I've done alot of things myself (on my Sup), so I'm okay with trying this too. I've never done 'em before, so I guess we'll soon see the results ;-)
Anyways, decision-maker for me.... $300 for a set that "someone else" rebuilt, or $20 and an afternoon to do 'em myself....
ƒ=1/2π(√k/m)
When my left rear caliper failed, I thought about the same thing.
Instead of buying a rebuild kit, or a new caliper... I traded my SSQV bov from YakuzaStinger here in town.
Works great now. :)
ur moms favourite
Works great now. :)
:scratch:
Anyway, rebuilding callipers isnt too tricky at all. I rebuilded some of mine a while back (first time i'd ever attampted it). I've since done 3 more sets for friends, its really no big deal - just get yourself some real long nose pliers for the circlip down the bottom of the cylinder
ur moms favourite
MK3Brent said:
"Just buy another working one."
Cheapest option.
A rebuild kit (even from toyota) is pretty cheap. At least if you rebuild it you end up with a calliper than is reliable and has lots of life left in it - who knows what a second hand calliper is like.
LEADED FUEL ONLY
I had a BITCH of a time getting the circlip in the bore. In fact.. mine isn't in correctly as its folded over itself. I got pissed and said screw it. i also ripped the boot on this same side as well.
If I had to do it over again, I'd buy a replacement caliper and roll with it. It would be well worth my time. Slide the old one off, slide the new one on and bleed the brakes.. done.
ƒ=1/2π(√k/m)
The boot is what was damaged on mine, and I think the road salt from MD got in there and caused all sorts of issues. :(
So far so good on my new one though.
ur moms favourite
You were using the wrong tools - simple.
I bought a pair of real long nose pliers (cost about $10) and ground the points down so they'd fit in the circlip holes. With these, removing and reinstalling the circlip takes about 5 minutes.
92 TURBO
87Turbo said:
Toyota kits don't include bleeder screws, at least for the rear calipers anyways.
^ The Toyota kits for the front don't either, only the rubber caps for the bleeder screws. I rebuilt all 4 of my original calipers with the Toyota kits, easy job.
^^Really? Wow, I was told that they did include the bleeder screws. I figured that's why I was getting 'em so cheap from Autozone. After my last bout with air in the system and never-ending bleeding sessions, I decided to get the speed bleeders anyways. Looks like I made a good choice anyways.
Where can I get the dust covers at? Since they aren't included in the kits.
LEADED FUEL ONLY
Maybe we're talking about different clips. Since I don't see how a wire that is uses to push outward could be held with a sert of needle nose pliers. This clip seals the boot to the caliper, not the boot to the piston.
I did get that circlip on, but the ends are overlapped. Not exaclty how it should be, but it'll work for a while. At lesat unitl I get mad at it and decide to tear into it again.
1 - 16 of 16 Posts
