1 - 17 of 17 Posts
hi guys, im in the middle of fitting my single turbo and need to fit the cam cover breather filter. the pics ive seen of peoples cars has this filter pointing straight up but the metal pipe points at an angle. how do i twist the pipe around to let me point the filter straight up?
Digital Tripod said:
Get a BIG ASS screw driver stick it in the hole and turn it. It is just a pressure fitting so it will turn with no problem.
i started to do that but noticed the pipe starting to distort so stopped. if its definitely pressure fitted i'll take the cover off and heat the pipe a bit
EchoDeDupra
you can build a catch can for really cheap...
not sure if I am understanding this correctly, but on my car, it keeps the oil/blowby from being dumped into my intercooler pipes and my intercooler. This hurts the efficiency. From what you are saying though, all that is happening is the oil is going to just go all over your engine bay.
Do a quick search on google. That's what I did, or get a cheap one off of e-bay if you don't feel like making one.
Discussion Starter · #12 ·
DLC said:
I had to turn mine with channel-locks. Screwdriver wouldn't work for me either. FYI, Summit's part # for the K&N filter you need is KNN-62-1330 in case you don't have the filter yet.
ive just bought the filters from obiwan knn-62-1360 though, i hope it fits ok
1 - 17 of 17 Posts
