Just finishing up my cam gear install, and was wondering-Do i have to set gears -3ex.side 1in.side before i tighten tentioner or can i do it after everything is tightened up?
Just loosen the the outer set screws...and then with a wrench turn the inner cam bolt to the setting desired. Basically, the cam will turn inside of the outer gear.
