1 - 3 of 3 Posts
By installing a 2.5mm Head Gasket would it be wise of me to also install cam gears? And if the answer is yes, do I have to get special NA cam gears or will all MKIV supra cam gears work (hks, aem, etc etc...?)
Found E85 NOT in NJ!
with my 2.5BL i seem to have soem trouble getting the timing belt onto the cam gears.....everything is lined up as it should
the crank is on 0
the cam gears are all facing up
and it looks like the belt is all lined up though it might be off on one side by a notch but that might be because of when i took it off
1 - 3 of 3 Posts
