1 - 4 of 4 Posts
Howdy Folks -
I've decided to milk a little more out of my current setup with some cams - I understand they push the power further up the RPM curve which is fine.
I'm running a T04R HKS single and am looking at cams that will be a good balance between additional power _and_ "streetability". I'm not really looking for brand opinions (I'll likely use HKS) but the intake/exhaust specs.
I know 272's are big power, but also pretty lopey from what I've been exposed to. I know HKS make a 264 as well as a smaller cam, like a 254?
I also have talked to a couple of tuners who do a "staggered" setup with a bigger exhaust cam.
Just wanted to get plenty of information before I make the purchase!
FYI, I'm going to be swapping out my Greddy Profec for a HKS EZ (the Greddy is peaking out on boost) - and see if I can get a couple of PSI more, plus the cams, and target the 650whp range.
Thanks in advance!
Re: Re: Cam Recommendations?
Thanks Andi -
That's what I've heard - and I also understand they're pretty "streetable". I even found a few used sets where people have upgraded to 272's - one set was $600! I should jump on one of those.
DT
Andi said:
264's are a good match for the T04R.
Andi
1 - 4 of 4 Posts
