Anyone have a good procedure on how to remove the cams? I know on the 7M there was a certain tightening/loosening sequence for the bearing caps.
Thanks!
Thanks!
can i also get it [email protected] thank youHamsMKIII said:Umm... Yeah...
Check your email. I just sent you a .PDF of the engine manual. You should find this very useful.
If you have any questions on shortcuts to make this faster, let me know. I haven't done it as much as Eric obviously, but I've got the swap down to 30 minutes now.
Chris
becauseican said:A quick question on the same topic, do you need to remove or replace the tensioner when loosening the T belt, for a cam swap?. cause I didnt remove it when I took it apart.
