1 - 2 of 2 Posts
ma70-7m=1JZ
Well I am in the middle of changing the valve seals and swapping in some 2jz cams into my 1JZ, and I noticed my front cam seals were leaking a bit. I have some 1JZ seals on order from Jaymarks, assuming they ever get here. Now I know that the seals are different between the 1jz and the 2jz, but scince I am installing the 2jz cams into the 1JZ can I use the 2JZ cam seals?. I measured the cams today and the face where the seal rides on is larger on the 2JZ cams, and this is one of the areas that need to be machined to fit the 1JZ. So I wonder if I can leave that face as is and just get the 2jz cam seals?.
Would anyone happen to have some 2jz cam seals that they could measure the outside diameter for me?
The out side diameter is huge compared to the 1J head. They will not work at all.. Sorry.
Cary
1 - 2 of 2 Posts
