1 - 7 of 7 Posts
2JZ S13
i did some searching and couldn't find too much.
i'm going to be swapping out my JDM camshafts and i want to run my new USDM camshafts.
and i need to know what the specs are for putting them in the head again any shims in there? what are the clearances? Thanks.
Boost4fun
If I am not totally wrong the learance should be 0,15-0,25 intake and 0,25-0,35mm exhaust side.
We have no hydraulic rockers in the head so you need to shim what´s neccessary.
Hope that helps
2JZ S13
thanks.....
someone i asked said i have to shim the cams?
does anyone have the specs? or what i have to plastigauge it to?
2JZ S13
thanks.....
T88 YOU
if you work on your car yourself and you dont already have them, you need to get the TSRMs. you dont plastigauge the cams, you need to install them and torque them down, then use feeler gauges to tuck between the bucket and cam... its all in the TSRMs:
here:
EM-48 installing cams
EM-5(towards bottom) adjusting valve clearance:
http://www.97supraturbo.com/1997 Service Manual/Engine.pdf
2JZ S13
Discussion Starter #6
here:
AWESOME! that's what i was looking for!:biggrin:
thanks.
1 - 7 of 7 Posts
