1 - 20 of 27 Posts
Who is using aftermarket cams on their NA-T? What sorts of gains and what grinds are you using? I am curious as I get the last few things together for the ethanol conversion on my car I want to figure out what cams to pair with it all..
I am looking at either the TTC cams or the MVP BC cams..I don't need anything crazy, but I want something better than the stock GE cams up top to take advantage of some more RPM on my S366.
If you want to shift the powerband to the right go with the bigger cams, for a street car some 264's would fit nicely, and I think you can still use stock hardware with those.
larger cams you will need to do springs etc...
Yup..I'm aware ;).
I have BC springs/retainers in there already, as I anticipated getting cams at some point. The stock cams didn't do too bad honestly..make peak power at 7k, but a bit more duration and lift would be nice..get that powerband shifted over a bit..give myself more powerband in boost.
i just installed both exh and int on my na-t as well as a haltech ps2000, results when i get everything working right.
Which cams did you go with?
bc 264s with the exhaust cam gear
Discussion Starter #9
Good deal! I am anxious to see how you do with those!
boost life
i have ttc 268 degree and love them .. the cams with a well designed ffim is what helped put me at 600rwhp @19psi on 93 oct .. car just keeps pulling
Discussion Starter #11
Any idea what you made before the cams?
Discussion Starter #13
Where are you making peak power now?
boost life
all in around 4800 peak power around 5800 ish , redline 8000k
Discussion Starter #15
What?! I made peak power at 7k with my stock cams and my S366...
boost life
I know many here in south Florida who complain about the laziness of the s366 .i guess tune and other supporting mods help . Also I'm around 9:4:1 ish cr
Discussion Starter #17
I don't have any complaints. I had full boost at 4300 in 4th. If I can rev out to 8k that is plenty of power and for me. I also don't have the space for big tired like you guys do, so the turbo coming on later does help some.
Over Medicated
I did an HKS 264 intake and TTC 268 exhaust. I was at 481rwhp @18psi before and 540rwhp after on 93 octane.
Discussion Starter #19
Awesome! Thanks!
What BC part number for NA-T guys still on a distributor??? I think it's BC03014 but not 100% certain. Anybody??
Thanks,
Shane
1 - 20 of 27 Posts
