1 - 7 of 7 Posts
Hey guys. I just installed some Tein Super Streets on my 89 Supra. They ride and handle great, but since it lowered it a lot my camber is very off. I tried googling camber kits thinking it would be an easy find, but I didn't find any for an Mk3. How have you guys corrected the camber or do you know if anyone makes a kit? Thanks in advance for the help.
Grumpy Old Man
If you lower the rear too much you run out of adjustment and will need to legthen the transverse arms 15mm to get it back within range.
I'll nevAr go single!
This brings up a question of my own.
I recently fixed front/right frame rail damage.
Without going into to much detail, it cannot be fixed perfectly. I dropped the car at the same time.
My camber on that corner is way out of specs and is adjusted the max it can go.
Is their a kit or replacment parts that can fix this? Camber is actually bad on 3 corners, but at it's worst on that one.
This goes back to the original post, which was not How do you adjust camber, but is their a kit to help correct it when adjustment is not enough alone?
Nice, thank you. Unfortunatley its only for the rear. Still a step in the right direction though.
1 - 7 of 7 Posts
