1 - 4 of 4 Posts
how much bend is allowed in new cams?
hello everyone, im looking into some hsk cams. 272
below is what is shown. is this ok?
what do i need to look for?
-There is no wear on the cams or hot marks, score marks ect
-The intake size is bent .002
-The exhaust side is bent by .0005
how much bend is allowed in a new set?
wish i knew :(
trying to figure out if this is worth the buy.
Inerax,
The TSRM lists the max run-out of the stock cams at 0.0031" or 0.08mm. Although these are not stock cams that you inquiring about, it should work fine... I have seen cams with 0.007" run-out turn easily by hand once torqued...
So, 0.0031" is a good starting point for you! Looks like you are good!
Regards,
Carlos
1 - 4 of 4 Posts
