Went to dyno the car last night 4/8/05
My old dyno run w/o cams
SAE: 524rwhp 493rwtq @1.8 bar (26psi)
Uncorrected: 541rwhp 509rwtq
New Dyno run w/ cams
SAE: 543rwhp 537rwtq @1.7 bar (24psi)
Uncorrected: 565rwhp 557rwtq
Webcam Specs:
Valve Lash: .008 intake .010 exh
Valve Lift: .322 intake .322 exh
Duration: 244 degrees intake 244 degrees exh
Duration @ .050: 218 degrees intake 218 degrees exh
Lobe Center: 107 degrees intake 115 degrees exh
Intake opens @ 2 degrees before TDC
Exhaust opens @ 44 degrees before TDC
Intake closes @ 36 degrees after TDC
Exhaust closes @ -6 degree's after TDC
Webcam Specs:
