They are 272s with the stock lift. With all the port work the higher lift is what I need. Or I'm wasting the new found flow.conundrum07 said:Another set? What were the first ones?
Yea we got it sorted out. The Echo buckets are 7 grams lighter too. Man the head really moves past .300 lift. We think the 12.5mm (.492)s will do the trick. After .500 the numbers level off. I have new numbers but we need the cams to really see were we are. We made a studed cam girdle toodrjonez said:man that's a lot of lift. you sort out the shim/bucket thing?
LOL. I'll post them, let me finish it up first. 11 grams damn.......chevyeater-on-sf said:Show us the cam girdle!! The 1SZ-FE lifters are 11 grams lighter BTW.
:TTIWWP:
Yea they are welding them up. They will be reducing the base circle also.adjuster said:Dang that is a ton of lift.
Are they welding on new material to increase the lift? They can't just reduce your base circle right? (or whatever they call it.)
Bored the head, real easy almost to easy. They are 32mm in diam.drjonez said:soooo, how'd you fit the echo buckets?
Yep. They drop right in. The hard part is getting them.drjonez said:chev- the 1sz buckets worked? they're jap-only, right?
They didn't look to bad. Still have good surface area.chevyeater-on-sf said:Oh yeah, how much was left of the cam journals after you bored the head? That's what made me go the extra mile for the 1SZ buckets.
Hey did you get them? Plus with my lift the cams will be right at the edge, so I need the Echo buckets. (Allan trying to sike himself out here)!chevyeater-on-sf said:Yep. They drop right in. The hard part is getting them.
