how much work to get them replaced?
err - that wasn't all that informative :fruit:not much
about a two hour job, really easy, if you have replaced the plugs or done brakes, then your good to go, I think 20$ for both seals and two hours of time. cover off, Tentioner lossen,T belt to the side, gears off, caps off, replace with new seals,RTV in the corners of the caps and reverse order caps, gears, tbelt,tentioner, cover. Eazy as pie.right. how much do i need to take apart to get to the seals? the wildest thing i've ever done on a car is changing plugs, oil, oilfilter and replace brakes...
that's what i was looking for - thanks a bunchabout a two hour job, really easy, if you have replaced the plugs or done brakes, then your good to go, I think 20$ for both seals and two hours of time. cover off, Tentioner lossen,T belt to the side, gears off, caps off, replace with new seals,RTV in the corners of the caps and reverse order caps, gears, tbelt,tentioner, cover. Eazy as pie.
http://www.supraforums.com/forum/showthread.php?t=362377
You can find the service repair manual here.
