1 - 3 of 3 Posts
Hey, I believe I am having TPS issues and was wondering if I could use the TPS that is on the TRAC throttle blade in place of the primary TPS on the throttle body. I have a spare engine with t-body and both sensors. I have already swapped out the TPS' but the problem still remains. Now I am thinking of trying the spare TRAC TPS in place of the primary one on the T-body to see if that makes a difference. Anyone know if it will work because they have different part numbers.
I thought I read somewhere you can use it if you reverse the wires because the trac TPS turn the opposite way of the TPS. So instead of 1-2-3-4 switch them to 4-3-2-1
Give it a shot see if it works.
1 - 3 of 3 Posts
