R
Redturbo
·Guest
I need to just see if I boost the right amount of HP
Did you cap off the passenger side PCV hose? The PCV valve, if functioning properly should block the air on the driver's side.Redturbo said:Im on like a search and destroy mission to find my boost leak and when doing so (pressurizing my engine) I took off my oil cap and and woooooooooooooosssshhhhhhh about 8 psi blew out of my crank case.......
There is a 1/2" hose running from the valve cover on the passenger side of the car to one of the intake pipes. (Pre-turbo) It is about 6 inches long. If you haven't blocked off this point you'd be forcing air into your crancase.Redturbo said:Idont know what that is....All I did was cap the exhaust and intake and put the comppressor hose into the hose that goes into the point where the stock turbo pipes meet and turned it on.
