i installed a new deck into my car.
i used the 2 plugs on the right.
but is there a way i can still do it so that i can get the oem sub working?
thanks guys
REVTECHRACING.COM
yes run a new speaker wire from the sub or catch it at the amp under seat and the wire it to your decks rear outputs in trimode. factory sub sucks so when you upgrade it itll sound a lil better.
I love sequentials!
If you use the connector that everyone recommends from Metra, the only other thing you'll have to do is run a power with key signal to the correct wire on the amp.
You have to get a deck with at least 2 preouts, leave those two plugs plugged in on the side, and use the oem amplified harness that plugs into the oem deck.
- Richard
Luvs ( . ) ( . )s
Anyone have a diagram? I'm kinda lost, but I have a DDX8017 with the toyota amplified harness adpater. How would I go about making the stock sub work again, the no bass is killing me.
