My friend purchased a VPC for his MR2, but never used it. It is brand new w/o a harness. Now, did the VPC come w/ the MR2 injector chip? What do I have to do to make it work w/ my Supra?
thanks
Roger
yes, you can use a mr2 vpc the pressure sensor is the same as in the supra set you have to hard^wire it into the factory harness. you have to order the right vpc chip for your car and set the dip switches for the supra as well. pls have a look for this procedure on the www.mkiv.com by tech articles under vpc install instructions. I already bought and mount an mr2 vpc for my supra, there was no problem.
Markus
mkiv bpu++ autom.
