1 - 8 of 8 Posts
· Banned
ahahhahahhahahhaahhahaha :lol:
as long as it says safe for LSD's then yer good
· Check Your Face!!!
is that synchromax shit any good? i have heard good things, but a forum member's opinions would be good
NegativeGeForce said:
i have read that just adding straight gear oil and then slowy adding lsd friction modifier till the rearend stops poping is the best thing to do. I am sure someone can clarify this better then I can.
Correct, this is for gear oil that does not already have LSD additive in it. As someone mentioned, redline 75w90 already has this additive in it and should be perfectly fine in your differential. I am running Redline Heavy Shockproof Gear Oil (arizona is hot enough) and it has worked great. I have also heard REALLY good things about gm syncromesh, however I do not know if it has lsd additive in it. Perhaps someone could chime in on this? (too tired to google).
· Dr. Jeff Lange
Some people believe the redline 75w90 has too much friction modifier in it though, so some prefer to get the 75w90NS, and then use Ford friction modifier and add it until the chatter stops. (Don't want to prematurely wear out that LSD. :))
1 - 8 of 8 Posts
