1 - 8 of 8 Posts
Wobbiest: Three Laws Safe
open - better cooling, longer engine life, cant hold as much power. can be sleeved to hold more power though, with less coolant flow however.
closed - opposite of all of above.
although engine life could be debated depending on design, build etc...
open - stock sleeves
open with modified sleeves
closed deck
its more like an open deck with supports...
semi-closed deck
  • Like
Reactions: Dresden
Discussion Starter · #6 · (Edited)
Ok, another stupid question, what is sleeving?
Seeing the pics more closely now I can see how the open deck gets better cooling and all. So I assume sleeving fills the gap that surounds the "piston wall" ??
Also is the 2jz an open or closed deck? I'm assuming closed but I have no idea.
Supra is closed deck. I think you have the ssleeving deal right...
in a way. it just doesnt fill the gap, it replaces the cylinder sleeves themselves after maching the block. your essentially knocking out the old cylinder sleeves and replacing them with soild or drilled ones that will allow less flex,more rigidity etc.
http://www.customdesignperformance.com/ecatalog/aebs_sleeves.html
they also make smaller braces that dont require as much machine work, but they suck to be quite honest. I think your thinking more along those lines...
1 - 8 of 8 Posts
