1 - 7 of 7 Posts
eighty-7t on SM
ok i dont know whats up with my car. it idles at like 1700 rpm, what do i play with for it to plunge down?
Just some guy
Check your throttle plate stop screw. You can also adjust the idle screw on the TB. Once you get it down, check your timing. Adjust as necessary to get both idle and timing right.
Christian
Livin the Supra Lifestyle
your idle shouldnt have anything to do with your timing. check the tb like racefiend said.
No One Ever Listens To Me
turn your AC off :D
oh yeah and do what was said above ;)
eighty-7t on SM
my ac dont work so no prob there. i'll do what was before. btw, why doesnt my ac work? i replaced the fuse, no luck..... :rant:
Your AC Clutch won't engage if the pressure of the gas is below a certain psi. It's a safety feature to keep the compressors from dying. Check the pressure in both you high and low sides of the ac system.
eighty-7t on SM
well i get no air no nothing. i can hear something behind the dash engaging but no air. is that caused by the same thing?
1 - 7 of 7 Posts
