1 - 4 of 4 Posts
The specs of the AEM EMS say up to 10 cylinder sequential. Does anyone know what it can do in semi sequential? Possibly 12 cylinders? Thanks
Discussion Starter #2
anybody?
wastegate hose is pulled
Semi sequential? Whazzat?
Anyway, you can control a gazillion cylinders with a distributor and batch fired injectors. There are a maximum of 5 coil drivers and 10 injector drivers in an EMS, YMMV based on EMS #.
you should be able to do 12 cylinders on the AEM by just using waste fire injection on 6 channels. That is of course if you use low resistance injectors in series.
1 - 4 of 4 Posts
