·I was just wondering if you could run the stock 9.5 in rims on the front or if anyone has tried it. It would be cool to run 9.5's on all four corners......
Hey Steve I was wondering why you have so little horsepower with the SP63? Are you still on stock fuel? Thinking about buying that exact Turbo kit. ThanksSteve Jarvis said:You will have to cut a tab off the front caliper before they will fit. Other than this they should work well if the spokes on the wheel will clear the caliper. You could run 265/40R18's on the front.
Later, Steve
Because he dynoed at 20.5 PSI and the turbo can be run at 30 psi.YuriZholtov said:
R5-Turbo said:I was just wondering if you could run the stock 9.5 in rims on the front or if anyone has tried it. It would be cool to run 9.5's on all four corners......
R5-Turbo said:Well, that kinda answers my question. I guess the thing to do is run a 255 or 245 in the front on the 9.5 in rims. Thanks for the info. The thing now is to find some TT rear rims.....
Steve Jarvis said:That doesn't seem to make sense. I have 265/35R18 on 18x9.5" 50mm offset and my tire doesn't stick outside the fender at all. As a matter of fact I just received some new 275/35R18's that I am putting on my 18x9.5" front wheel. Maybe the stock rear wheels aren't really a 50mm offset. I have to look at some a verify it one last time.
Later, Steve
