After engine removal and replacement, I was using "49 steps..." and it said to just let the drive shaft slip out and reinsert it later, well, I am to that point now and canont get the shaft back into the tranny....it is as if they are turned differently. What is the trick to putting the shaft yoke back into the tranny? Thanks.
LEADED FUEL ONLY
Remove the 2 bolts holding the center carrier bearing. Then you can manipulate it however you need. You may need to spin the driveshaft a bit in order to aling the splines.
475RWHP 449TQ and climing
No more needs to be said.
