EDIT: problem solved, scroll down to the bottom for the solution
first i had a hickup during regular accelerating (acceleration would pause for split second, then resume)
then it would backfire at around 3k
then it died while driving (rpm needle went up down and all around)
it restarted like two or three times, but died shortly after. during it's short runnings, it had a miss that i proved to cyl 6 not firing.
throwing code 14 mainly, sometimes throw code 31
i'm going tomorrow to check the resistance values of the cam/crank sensors
is there any way to check the ignitor as i don't know anyone in my area with one.
thanks
EDIT: is there any point in checking the cam/crank sensors if i didn't get a code 12 (which i believe is cam/crank sensors)???
thanks
