1 - 14 of 14 Posts
JZA70 448 rwhp everyday
When i drive normally (slow for me ) My car never dies at idle. If i get on it (boost, and ~4000RPM) and push in my clutch my car just dies. If i let it rev back down to ~2000 RPM then push in my clutch then im good. I can drive around this problem, but I dont want to. Could I be stuck in safe mode, or cold start mode? How can i verify this? I know im running rich because of my dark plugs. Notable info is that i have a Lexus AFM, 550s, no piggy backs, and a hks bov? Also I'm having trouble gettin my TPS in to spec, but i have all the TSRM specs?? Any ideas? :dunno:
~scott
1991 1JZ
deccelerate instead of just boosting then pushing in the clutch, leave it in gear and slow down with the engine still in gear.
also try tightening your BOV a little bit.
yes, my BOV is vented to atmosphere. Should i try and tighten it up so it keeps more metred air in my charge pipes?
~scott
was your stalling similar to mine? My car seems to run too well for my AFM to be off? Ill check it tonite. If i let the car rev down (still in gear) then clutch at like ~2000 RPM then i dont stall, only after boost / ~4000 rpm?
~scott
Discussion Starter · #10 ·
Yea, i was also looking the dashpot on TSRM...so that would mean my screw on the bottom of the TB is out of spec, or is my problem related more to the little air filter on the end?
~scott
boost freak
has nothing to do w/it being in/out of spec. what you need to do is look @ the function of the dashpot- it holds the throttle open for a bit when you let off. tighten it up (i.e. make it hold the throttle open more) and it should cure most of your stalling problems....
It's either the dashpot as Dr says or a vacuum leak. I had the same problem with mine after a rebuild, and it turned out to be a vacuum leak on the #6 injector insulator.
1 - 14 of 14 Posts
