·Hi all hope you can help when running my car its fine when first started but as it warms up the revs die and the car stalls. Also when driving if i press in the clutch the revs drop to 0 and the car cuts out or at junctions the car will cut out. I have changed the requlator, fuel pp, idle air vv, throttle position sensor all to no avail, when it happens its almost as if whatever should catch the dropping revs is doesnt so. Also when it is happening and the car is at the struggling stage the battery volts drop but im not sure if this is standard stall indication. Any ideas will be greatly recieved.
