1 - 2 of 2 Posts
My car does starts up and kills. It threw a MAF sensor check engine light code. The problem is when I go to unplug the MAF sensor the car idles fine. HAS ANYONE EVER SEEN THIS PROBLEM??? I just put a single turbo kit on my car. Do you think if I buy a MAP ECU and get rid of my MAF meter then my car will be ok???
Boost4fun
Yes I think that would cure your problem..
But for the time being: How have you routed your IAC valve hose? Do you use a lil breather on it? Then your symphtom might be normal since the air for the IAC NEEDS to go through the MAF first before entering it.
Gerd
1 - 2 of 2 Posts
