Well today I installed me greddy type-s BOV along with some hardpipes. After the install I revved it up to test the BOV and when the rpms went down it died, and will die if I don’t keep on the gas. I got some kind of vacuum leak some where I just cant find it. Any one knows of any easier way of finding the problem area?
Supranian
Back track everything that you did to try and find where you may have knocked off a hose. Some people use starting fluid or wd-40 sprayed near some of the fittings to see where the engine jumps to locate the leak.
If the bov is vented to atmosphere it will stall. The air its venting was already metered, and fuel was sent to the engine to burn with that air that is no longer there, hence its rich and stalls.
It may. I would stay closed atmosphere or go SS unless you've got a stand alone that compensates. It'll run better. To me that's more important than scaring neighborhood children.. (but only barely :) )
Oh, IMO. :bigthumb:
