1 - 13 of 13 Posts
Changed ignitor nothing.I checked resistance of crankshaft sensor.It was 1312 and the manual said cold 1630-2750 (page IG1) for resistance.This I take would be the problem?The reason Im posting is that the manual later says normal range for Crankshaft sensor page IG-4 says range is 835-1400.Now this I think is a typo as that is the resistance range of the Camshaft sensor.I just dont want to order another sensor if I dont need one.Im a newbie here as well and any help would be appreciated.I couldnt find the step by step instructions to replace the crankshaft sensor.Any help here would also be appreciated.BTW I also have the proefi which I think is fine?
Are you running AEM?
If your car turns over but doesn't fire you may need another battery. Voltage may be dropping to low.
first, check the fuses for the EFI. Next, make SURE the ECU is plugged all the way in. After that, pull coilpacks and check to 100% verify there is no fire. Do all that, then report back.
No spark no start makes sense in a way.
If car was running before, I would check the cam sensors.. I wonder if Proefi uses both like stock ECU (AEM and MOTEC don't). Make sure they are well plugged and eventually switch them around.
I don't trust testing anything anymore. I had a dodge stealth that had this exact problem. Every sensor and module tested good according to the service manual. It was six months later before I found out it was the ignition module that was bad and only because someone else on the forum had the same problem and somehow go lucky. I swapped it with a known good part and it worked. Just an FYI
Discussion Starter #12
I switched cam sensors and it starts!! I did talk to SP and the Pro EFI just uses one cam sensor.I would also just like to thank everyone for there help.My big question now is do I send the Ignitor back or keep it.The old ignitor has 70000 miles on it.
im having a problem similar, last nite car started right up no problem, i shut it down and called it a nite. This morning i wake up and go to start car and nothing, it cranks but does not fire up, i changed out spark plugs, checked fuses in the engine bay, checked to make sure program was still on aem, i cant start to think what it could be... any opinions? i'd appreciate the feedback,
thanks,
Marc
1 - 13 of 13 Posts
