ok, my car ran fine just the other day. then my brother went and disconneted the battery cable to reset the ECU for whatever reason. well then i expected it to run like ass for a while and die and stuff. well i drove it a lot and it should have relearned.
when i start it in the morning the motor is cold so it idles a bit higher and idles fine. then when it warms up it idles at about 350-450 and eventually ends up dieing. i checked for codes and there is None.
when i drive around and come to a stop the car dies all the time.
what do you think could be wrong and what do you think i should check?
does it sound like a ISC problem even though there are no codes?
thank you.
Jonathan
no i know its not the afm. it runs and boosts fine and doesnt sputter. it just doesnt wanna idle.
i got the same problem.... when its runnin tap the black pice on the afm and see if i helps atall
some times it works. but it probly is a bad afm try and get one of a buddy or somethign and try it.
i just raised the idle for now. i read some threads about it but didnt come up with much besides ISC and someone having to let their ECU re-learn and it took like 80 miles to do so which was wierd.
