Ok guys…. I need some serious help and I need it from the guys that pretty much know the cars from in and out…. Here is what happened today.
I put the JIC coilovers on the car yesterday. Car sat really low. I completely forgot to raise it and left it as it was…. Long story short… driver side is missing the wheel well cover so the tire somewhat shredded my wires. Barely grazed them but managed to pull them a bit…. To the point all my interior lighting / gauges had turned off and exterior lighting wasn’t responding as well. Ok….I pull over placed it in park and turned the car off. When I tried putting it back in gear it wouldn’t go so some guy says….
“You have a safety switch that you can put it into neutral. The mechanic will know how to reset it”. (pushed the little button by the shift lever) So we did that and pushed the car out of the street. AAA tows car home. Where I finished my wiring dilemma. Plugged everything back and all the interior / exterior lights work again…..
PROBLEM:
Car will not crank over at all now. I’ve checked all my fuses in the bay and interior. What is causing it not to crank? My first guess is that “park / neutral switch” that we pressed…. Or the factory theft deterrent system.
How does one go about resetting the park / neutral switch?
OR
Reset the theft system ?
Clearly it’s something blocking it from proceeding to startup.
Solution to turn it on:
I jumped the starter relay pin 1 and 3 to turn it over and it fired right up like normal. So…. I know something is just in safety mode. I need this fixed before Friday. SOMEONE…. HELP ME PLEASE!!!!
I already took out the ecu1 and ecu2 fuses from the relay box and unplugged the battery. Checked each fuse at the junction box by the foot. Everything is responding as it should.
Thanks guys
PROBLEM:
OR
Thanks guys
