1 - 4 of 4 Posts
I finally figured out my starter problem and now the car cranks, has fuel and spark, fire starts and doesn't idle at all. Dies the second you let off the throttle. I even readjusted the timing, took the entire cps, etc. I'm lost, also my gauge cluster doesn't want to work either so that's also another problem, the gauge fuse is fine. I took a video of how it starts and sounds:
http://www.youtube.com/watch?v=dkJKYcMke6I&feature=player_profilepage
Thanks for all the input!
hey i had the same problem all winter here with my 7mgte swap for me it was just way off timming and usin platinum plugs (they dont like them i guess) and did you adjust the idle screw near the troble body under that lil black cap?
we re-timed it and its running autolite copper plugs. Also, we took the timing cover off and the exhaust cam gear wobbles when the car is running. Its not a lot of wobble, just enough to notice. We checked for intake leaks, moved around the cps and even changed the idle air control valve, I'm completely lost.
1 - 4 of 4 Posts
