Just put my car back together and I cant get the car to rev higher than 2500rpm's. I checked all the vacum lines and wires. Has anyone had a problem like this????
QUick question. Do you you have a S-AFC? I had (I believe) my sensor input type set at Karman by mistake and it never made it past 2500 rpm. In fact the car wanted to die if I didn't let off by 2500 rpm. I set it back to Hotpoint (correct?) and the car is monney all the way to redline. I know it's a longshot, but I hope it helps.
Most likely your ECU is not getting the proper incoming air signal from the MAF. In that case ECU opts to "fail-safe" mode, and allows you to limp back home at up to 2500rpm, until the signal cuntinuity is restored. Check and make sure it's connected securely, and that you haven't pinched the signal wire anywhere.
MONSTER- Thanks for the suggestion. I was helping him replacing the oil pump. The engine was lifted up and out towards the front about 6-8 inches inorder to drop the oil pans. We were making sure not to damage any wire harnesses. Do you think we might have over stretched one of the wires in the harness in the engine compartment possibly breaking one of the signal wires?
Cowboy Bebop- He doesn't have the S-AFC but VPC and GCC instead.
wingz, since he uses VPC there is no use for factory MAF harness.......hmmmmm.......engine definitely seems to be operating in fail-safe or limp-home mode.....
After I have installed all the new seals, BCsprings, retainers, locks and buckets,
with T-belt off, put crank at -10 btdc so all pistons are slightly down, install new BC 272 cams, install cam gears, torque cams as per manual. Then turn CAMS clockwise to tdc notches, and than turn CRANK to tdc...
Recently acquired a rhd supra and slowly starting the process of swapping things over. Got myself some glass headlights and wanted to swap bulbs while I’m at it. Been told jdm lights differ from usdm. Hard finding more info on this. Thoughts? Trying to find a quality hid system, seems LED isn’t...
I came across asking myself today, do you need a igniter when you go to a aftermarket ECU and Harness? I noticed my friend is running a MOTEC and does not have one for his car.
Hey guys,
Just installed a pair of S2 taillights on my 93 Supra RZ. I would like to convert to LED. I would like to purchase from here as the prices seem very good.
https://www.superbrightleds.com
According to my search in the Forums, looks like I need 2 x 7440 and 2 x 7443 bulbs Just not...
Hey guys,
I had a boost leak on my 94 BPU for years and didnt notice it because I still got good boost. So I finally fixed it but forgot to turn my boost controller down. I hit 25 psi 2 or 3 pulls without realizing it. Since then it wont go much over 14 psi anymore.
I did a boost leak test for...
