What can cause BL built tranny to require manually shifting into OD to avoid slippage? Otherwise car runs fine, and tranny shifts good at WOT....but spot right before OD slips unless its manually kicked into OD.
Thanks for help
Ensure you have the proper level of tranny fluid...would like to know for the heck of it as well. Update the post when you figure it out well ya...
If I leave it in OD mode from the start, and gun it, it goes thru gears properly and when its about to shift into OD it just spins...but if I leave it in #3, and then get up to speed, and then bump into OD it locks into OD immediately without any "slipping". Otherwise car runs fine, fluid is fine. I'll call ya
Sounds like the Valve body... Prob need to drop it and Clean it... but, that is just... MO
