1 - 12 of 12 Posts
This morning was the 4th time I have noticed this. When I take my foot off the gas especially between 20-30mph the car keeps going like the cruise is on. The other day it happened at 55mph. Going through the school zone this morning I had my foot off the gas and it cruised right through at 20mph for at least 1/4 mile.
is it auto or stick .i had the same problem with my sc 300 ,but it only did it when it is cold .went away after a tranny flush
auto & had the tranny service done 2000 miles ago. Your right I notice it more before it warms up, like within 2 or 3 miles of home.
King Ding-a-ling!
I had this problem on my turbo grand prix back in the day. Everytime it happened, I soon lost the tranny. (I beat the shit out of that car!) I beleive it had something to do with the torque converter not working properly.
Brandon
Professional OT Bum
If its cold your engine may be on a higher idle speed to warm up, and if your in 4th gear it will idle high and keep you at that cruising speed, unless otherwise I wouldnt worry.
Discussion Starter #6
Weird, my car only has 65k miles on it. It shift hard and doesn't even come close to slipping.
sticking throttle body butterfly can also cause this
clean and regrease the throttle linkage with white lithum grease
Discussion Starter #8
Where is that on the engine? Do I just follow the throttle cable to the linkage?
check your throttle cable also. maybe the cable itself is breaking somewhere causing it to stick. since the cable is a bunch of wires twisted together to cover another wire the outside layer of wires can cause it to stick. fixed a problem like this on a celica. might just wanna check that out.
wasting my life on SF
Brandon
it sould slike the torque converter wont disengage like its locked up.
It doesn't necessarily sound like there is anything wrong. If the car is in second and idling at XXXX rpm. If that rpm corresponds to a certain speed 20-30mph and the engine at that rpm is producing enough power to maintain that speed why would the car decel.
1 - 12 of 12 Posts
