I tried to use search and advance search on Google, but couldnt find anything SO maybe someone on here can shine some light on my problems.
We just got done installing the BL 67mm single kit. I'm pretty sure I have done everything by the book... For some reason when i start the car it will start for like 2 seconds, stumble and die. If if give it a little gas once it starts it will continue running and seem normal, but will still die once I let off the gas. I'm am pretty sure i have done all the small thing like the EGR block offs, put resistors in the 4 plugs on the turbo side that used to plug into the stock twins.... Are the any things you guys can think of that I need to check that I could have possible missed?
BTW: The car is still on the MAF, and will be running a AFC Neo for the time being.
